Вернуться   JEEP-FORUM.RU - ДЖИП-ФОРУМ.РФ - Форум JEEP-ов > JEEP технический раздел > Jeep Grand Cherokee и Jeep Commander
Старый 20.10.2012, 18:16   #1
G_STAR
Аватар для G_STAR
Марка: Commander 4,7
Exclamation Спецификации масел и жидкостей для JEEP COMMANDER V8 4,7
чего куда и сколько лить??? ПОМОГИТЕ!
1J8H3E8N86Y127802
1: Manufactured By DaimlerChrysler Corporation
J: Jeep
8: Multipurpose Passenger Vehicle
H: 6001-7000# (2722-3175 KG) GVWR & Hyd Brakes
3: Grand Cherokee Left Hand Drive (4x4)
8: Sport Utility 4 Door
N: 4.7L V8 CYL Gas
8: Check digit
6: 2006 Model Year
Y: Chrysler Steyr Assembly
Код модели кузова: XHJH74
Двигатель: EVA 4.7L V8 MPI Engine
Коробка передач: DGE All 5-Speed Automatic Transmissions
Модельный год: 2006
Дата производства: 26.01.2006
G_STAR вне форума
Старый 20.10.2012, 20:05   #2
G_STAR
Аватар для G_STAR
НАШЕЛ! выкладываю в оригинале
Fuel (Approximate) 20.6 Gallons 78 Liters
Engine Oil with Filter
3.7 Liter Engine (5W-30, API Certified) 5 Qts 4.7 Liters
4.7 Liter Engine (5W-30, API Certified) 6 Qts 5.7 Liters
5.7 Liter Engine (5W-20, API Certified) 7 Qts 6.6 Liters
Cooling System *
3.7 Liter Engine (Mopar Engine Coolant/Antifreeze 5 Year/
100,000 Mile Formula)
9 Qts 10 Liters
4.7 Liter Engine (Mopar Engine Coolant/Antifreeze 5 Year/
14.5 Qts 13.7 Liters
5.7 Liter Engine (Mopar Engine Coolant/Antifreeze 5 Year/
Engine Coolant Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic
Additive Technology)
Engine Oil (3.7L/4.7L Engines) Use API Certified SAE 5W-30 Engine Oil, meeting the requirements of
DaimlerChrysler Material Standard MS-6395.
Engine Oil (5.7L Engines) Use API Certified SAE 5W-20 Engine Oil, meeting the requirements of
Oil Filter (All Engines) Mopar Oil Filter (P/N 05281090)
Spark Plugs Refer to the Vehicle Emission Control Information label in the engine compartment.
Fuel Selection (3.7L and 4.7L Engines)
87 Octane
Fuel Selection (5.7L Engines) 87 Octane Acceptable - 89 Octane Recommended
Automatic Transmission Mopar ATF+4 Automatic Transmission Fluid
Transfer Case (3.7L Engines) Mopar ATF+4 Automatic Transmission Fluid
Transfer Case (4.7L/5.7L Engines) Mopar NV 247 Transfer Case Lubricant
Axle Differential (Front-Rear) Mopar Synthetic Gear & Axle Lubricant SAE 75W-140 (API-GL5) or
equivalent with friction modifier additive.
Brake Master Cylinder Mopar DOT 3 Brake Fluid, SAE J1703 should be used. If DOT 3, SAE
J1703 brake fluid is not available, then DOT 4 is acceptable. Use only recommended
brake fluids.
Power Steering Reservoir This system requires the use of Mopar Hydraulic System Power Steering
Fluid (P/N 05142893AA) or equivalent, which meets DaimlerChrysler Material
Standard MS-10838.
G_STAR вне форума
Старый 21.10.2012, 01:26   #3
Николай Пименов
87 бензус "по-американски" - это 92 "по-русски". Примерно конечно. Но не 95й!
Добавка в диффы нужна если у вас квадра-драйв (самоблоки в мостах).
Николай Пименов вне форума
Старый 21.10.2012, 19:25   #4
G_STAR
Аватар для G_STAR
Марка топлива ГОСТ ТУ Октановое число (Моторный метод) Октанове число (Исследовательский метод)
А-76 ГОСТ 2084-77 76 не нормируется
АИ-80 ТУ38.001165-87 76 80
АИ-92 ТУ38.001165-87 83 92
АИ-95 ГОСТ2084-77 85 95
АИ-98 ГОСТ2084-77 88 98
G_STAR вне форума
Старый 21.10.2012, 19:26   #5
G_STAR
Аватар для G_STAR
столбцы
1название у нас 2гост 3моторный метод 4исследовательский метод
ИТОГО!
амер 87 это НЕ НИЖЕ 95 у нас
G_STAR вне форума
Старый 21.10.2012, 19:40   #6
Николай Пименов
Фантазер..
Американское число получается моторный+исследовательский/2.
Получаем.
АИ-80 76 80 = 78 ам
АИ-92 83 92 = 87,5 ам
АИ-95 85 95 = 90 ам
АИ-98 88 98 = 93 ам
Итого: настоятельно рекомендуется 92й бензин...
Старый 22.10.2012, 15:24   #7
G_STAR
Аватар для G_STAR
этого факта не знаю, а вот что в амер авто указывается моторный метод - слышал
G_STAR вне форума
Старый 22.10.2012, 18:25   #8
Николай Пименов
Слышал звон, да не знаю где он. Инструкцию надо не тупо читать, но и на картинки смотреть. Внимательно читаем про способ определения чила на картинке (выкопировка из американского юзер-мануала от ГЧ 95 года)
Для особо талантливых - R=research, исследовательский, M=motor, моторный (методы).
Последний раз редактировалось Николай Пименов; 22.10.2012 в 18:31.
Старый 22.10.2012, 21:10   #9
G_STAR
Аватар для G_STAR
спасибо! буду знать)
G_STAR вне форума
Старый 22.10.2012, 22:00   #10
Николай Пименов
Если учесть, что эта картинка в русский мануал не продублирована, некоторое незнание простительно.
Текущее время: 07:45. Часовой пояс GMT +3.
