#1 | |
Марка: JEEP Grand Cherokee WJ 4.7 247 2001 г. светло-серый
Марка: Jeep Grand Cherokee 1997, 5.2, черный
Во че нашел http://www.avtomaslo.org/podbor-masla-mobil-1
Показывает, что если эксплуатация при меньше 0 градусов то нужно 5w30 , если выше 0 то 10w30 а какое из них лучше на лето? 5w или 10w Mobil 1 Extended Performance 10W-30 Mobil 1 Extended Performance 10W-30 is our most advanced, full synthetic motor oil, proven to protect for 15,000 miles between oil changes. Guaranteed. Mobil 1 Extended Performance reduces engine wear and oil breakdown, even during longer service intervals, to help extend engine life. Mobil 1 High Mileage 10W-30 Mobil 1 High Mileage 10W-30 is an advanced full synthetic motor oil that is designed especially for higher mileage engines. Mobil 1 High Mileage outperforms our conventional high mileage oil and helps extend engine. Seal conditioner is added to help prevent leaks. Mobil 1 10W-30 Mobil 1 10W-30 is an advanced full synthetic motor oil that helps extend engine life by reducing engine wear and oil breakdown. Mobil 1 10W-30 provides outstanding performance under all operating conditions and meets or exceeds the warranty requirements where an API certified oil is specified. Mobil 1 0W-30 Advanced Fuel Economy Also consider Mobil 1 0W-30 Advanced Fuel Economy, an advanced full synthetic motor oil, for vehicles where a SAE 0W-30, 5W-30 or 10W-30 oil is recommended. Mobil 1 0W-30 Advanced Fuel Economy is engineered to deliver outstanding engine protection and a potential 2% fuel economy improvement based on a comparison versus those grades most commonly used. Actual fuel economy improvement is dependent upon vehicle/engine type, outside temperature, driving conditions and your current engine oil viscosity. Mobil Super High Mileage 10W-30 Mobil Super High Mileage 10W-30 provides additional protection to help extend engine life in vehicles with over 75,000 miles by helping reduce oil consumption and prevent sludge build-up and engine wear. Mobil Super High Mileage 10W-30 contains seal conditioner to help protect higher mileage engines and prevent leaks. Consider Mobil 1 High Mileage 10W-30 for even greater protection and performance. Mobil Super Synthetic 10W-30 Use Mobil Super Synthetic 10W-30, a full synthetic motor oil, to help extend engine life with high temperature protection in addition to the sludge and wear protection of the other Mobil Super products. Consider Mobil 1 10W-30 for even greater protection and performance. Mobil Super 5000 10W-30 A premium conventional motor oil, Mobil Super 10W-30 helps extend engine life w
Люблю українську природу, гарячий борщ, холодну воду, і повну пазуху цицьок!
Последний раз редактировалось Mr.X; 27.02.2011 в 19:50. |
ты масло собираешься в космический корабль заливать?!
неипи себе мозг.лей 5w30 или 5w40 всегда !!!!всё будет гуд!!!
"познать,то что есть,ибо то что есть,есть разум" (Гегель) |
то есть лучше 5w30, а не 10w30 на лето.
и чье производство Мобил оригинал?
можешь на лето и 10w30 залить,а на зиму 5w30.масло не обязательно мобил,главное качественное.
Марка: Grand '96 5,2 Limited; Ford Focus 2,0 Titanium; Mitsubishi Pajero 3,5 GDI; ГАЗ 2402 1978 г.в.
Лью 10W40 круглогодично, запускается нормально, проблем с двигателем никаких.
ZJ 5,2 limited 1996 Yokohama G012 AT/S 235/70R16 |
#10 |
Ребят,а в двигатель лью маннол 10W40 ,даже гидрики не стучат в любых температурных диапазонах. А давление меньше 3 очков на горячую не опускаеться.
Мосты от WJ !!! DANA30 varilok, DANA44 varilok,. Лебедка Winch 12000. Рычаги перед,зад от Паджеро2. Bushwacker. Шноркель.Подножки от 200-го крузера. РК-Pajero"Super Select". МКПП NSG370. Хабы переднего моста, цапфы. Калитка запасного колеса.QD32ETI. Теперь СУПЕР!!!!!!!! Счастье там, где кончается асфальт...
